Which ABS...again
jacksdad63
Manchester
Hi, I've tried to work out which ABS is fitted on my GS. Its registered late march 2007, one tag on the diagnostic plug loom says 11/2006.
I've looked at the wiring diagrams, the 2006 bike has a yellow/white wire going from the ABS to the plug: Mine hasn't got one, which points to 2007 model.
The V5 says its a R1200GS 04, but I have no idea what the 04 bit refers to.
Its all working! I've started the bike, applied the front brake, and when you trun the rear wheel, I hear the ABS motors working, and the brake is applied after a second or two.
How do I work out which model bike I have, and which version of ABS?
Thanks again everyone!
nice the one I found here is a good one that updates as options get added - bold went on the bike about 2020 some 13 years down the road from original build
I-ABS generation 2 - is the later semi-decent system - list below is my June 2007 built bike
X0321​
Headlight left asymetric​
X0326​
Speedometer mph​
X0350​
Exhaust system, chrome​
X0381​
Operating instructions, English​
X0420​
Side section, schwarz​
X0519​
Heated handlebar grips​
X0530​
RDC​
X0539​
On-board computer​
X0588​
Turn indicator, white​
X0589​
Hand protector​
X0603​
Alarm system​
X0630​
I-ABS generation 2​
X0681​
Case holder left/right​
X0736​
National version Great Britain​
X0773​
Seat, black​
X0650​
ASC​
Thanks botus, thats a cracking site, my bike is very similar to yours, says production date is 11/01/2007, so it was made then registered in just over 2 months!
The ABS says the same, X0630 I-ABS gen 2.
My rear brake pedal has a lot of travel before the brake works, I'm thinking I can try bleeding it like a non ABS system?
no problem to try bleeding the brakes the conventional way - but might not get all the air out of the ABS valve block - with decent diagnostics there are a number of functions to allow you to bleed that effectively
Thanks again: Can I buy the diagnostic tool? I've seen a few devices for the Bee Emms but not sure which does what! I drive an Isuzu 4x4, I bought a chinese copy diagnostic kit for that, works perfectly and has saved me a fortune, plus I've fixed a few others for a few £££'s back :D
nasty Chinese dongles are not safe and may not work to get a real features...
when reading fault codes a £10 one might work -but for real stuff they are dangerous and best in the bin a good dongle is £50 to £60
the motoscan app is about £40 from wgsoft - see playstore (only buy the ultimate version)
