...............in particular the BMW RT which is very suseptable to this ) could cause failure of your ABS .
Obviously the reverse of this is that the RT also produces a lot of emissions at the front of the bike and would reduce the performance of your PMR446.
Thanks for sharing that Ming. Could you point me in the direction of the data relevant to the RT susceptibility to EMI - would like to know more
I suspect that a respected company such as Panorama use quality low loss coax along with high spec cutting, stripping and crimping tools. They supply some of the Tetra kit for police bikes I'm told
The technique of bonding the outer coax shield to the bike's frame is interesting - any chance of more detail?
The A80 is claimed to be "mil-spec", has a metal chassis and is CE stamped so I'm hoping 0.5w will be reasonably bulletproof as far as spurious emissions are concerned
My mate has a similar setup to mine on his '06 1200GS with the PMR just behind the tank and a 5/8 whip over the instrument cluster and has yet to report any problems
