IMO the big issue with ALL modern bikes is the designs are all stuck. Yes they've added electronics and changed the styles but apart from BMW using Hossack derived suspension (1990) and Piaggio with the MP3 scooter (2006) nothing ground breaking is happening. TBH the scoots seem to be getting the interesting ideas (Peugeot with a hybrid idea). The latest Skidoo is is more ground-breaking than the new BMW boxer
Bikes are all part of the motor industry but compared to cars, bikes have not really changed.
We may think otherwise, but the market is actually pretty averse to innovation. Why else do you think the boxer twins (of which I proudly own two) have survived for so long? Ditto the Porsche 911 rear-mounted flat six which, on paper, is far from an ideal engineering solution?
IMHO, aside from making the things less expensive to run (especially in terms of fuel, which for us is now approaching European levels), if it ain't broke, why fix it?
What does a motorcycle really need? Two wheels and a propulsive system of some kind.
Hybrid engines are an expensive, complicated, fussy, ultra-high tech solution to a problem far more easily and cheaply solved using small turbodiesels. Now THAT, I wouldn't mind owning.
What about 2 strokes today's are clean, powerful and economical. They are hugely less complicated than 4 strokes so why not?
What about DSG gearboxes?
The death of the two-stroke engine was politically motivated by the American and EU anti-emissions eco-mentalist lobby.
As such, it's extremely unlikely to come back.
Also, deux-temps use more fuel per distance travelled. Not so much of an issue in the days when petrol was cheap.
DSG gearboxes - again, a high-tech solution to a problem that doesn't exist. Modern sequential gearboxes are well-engineered, easy to use and, thanks to high-volume production, relatively inexpensive.
IIRC, Honda first tried this in the eighties. Market reponse was lukewarm, so they dropped it. But I've seen it coming back on things like the NC700 and VFR1300, in switchable full-automatic / semi-automatic-by-pushbutton guise.
