Will rukka gloves give a bit?
GSWizz
London, England
I have just purchased a pair of Rukka Pluto gloves online from Infinity. I ordered size 9. They seem a very tight fit on the hand but I have a bit of room in the fingers. I have a pair of summer gloves in size 9.5 which are a touch loose.
Will the Rukka gloves give a bit or should they go back?
Probably not :nenau
I have a pair of Rukka gloves .... I needed to go from my normal size 9 - 9 1/2 to a size 12 with the Rukka for the same fit!
Does the finger length remain realistic in a 12. My dominant hand measures 9cm at the widest point or 8.5inches all the way around.
I am wary of ordering a 12 and the fingers being way too long.
I currently have the same issue and similarly ordered the same glove in same size from infinity (my hand 9" in circ.).
Have worn 4 or 5 times now and are beginning to give, am reliably informed they're a great glove.
I'm going to stick with it for fear of having to otherwise endure long, flappy fingers of a larger size.
The size 12 Rukka Hero are just right in the finger department for my normally sized 9 - 9 1/2 hands :)
If your gloves are gore-tex you don't want to be stretching and compromising the gore-tex :nenau
Probably not :nenau
I'm the same as Micky, normally a size9/10 suit me, in Rukka gloves I needed a 12 and the fingers are not notably much longer so they fit fine.
