Win7 -changing file associations?
NeilF
officially THE best place to live . . . . Wokingha
Under Control Panel>Programs>Default Programs>Set Associations I have my .pptx (Powerpoint files) currently defaulted to be opened by Internet Explorer.
When I double-click on this display line, to go to the "choose program you want to open this file" I then don't know how to browse or find the Powerpoint application. :(
That's what I need your help on please!
Cheers,
Neil.
Look for and select MS office in the Open With List, that should do it.
Right mouse click on a powerpoint file - choose "Open With" - choose "Browse" - find the "C:\Program Files\Microsoft Office\Office12" folder (the 12 might be different for non 2007 version) - select the "POWERPNT.EXE" app.
Thanks Clive (and Alistair & Dickie)
My issue is that when I navigate as far as the "C:\Program Files\Microsoft Office\Office14" folder I can only see two files in there - one's a .dll, and t'other is a propdesc.
Selecting either "All files" or "Programs" (*.exe", etc) doesn't show up the Powerpoint.exe that we're looking for.
Is it the program attributes that I need to change to display the powerpoint.exe?
Thanks so far
Neil.
Thanks so far
Neil.
If you are running 64 bit Windows 7 - have a look for the folder under C:\Program Files (x86)\etc
(edit - are you running 32 bit or 64 bit Windows 7? I presume you have 32 bit Office 2010 - I've got Office 2010 but not installed it anywhere yet)
64-bit Win7 Home Premium. 32-bit Office 2010 I believe - don't need any of the "64-bit Office features".
Nothing under \Program Files (x64) either for that little Powerpoint exe . . . .
Hmm - I've just installed Office 2010 in addition to Office 2007 (rather than an upgrade) and it is in
C:\Program Files (x86)\Microsoft Office\Office14\POWERPNT.exe
Maybe the elves have stolen yours.
64 bit Windows has "Program Files" for 64 bit apps and
"\Program Files (x86)" for 32 bit apps.
How about if you make like you're going to start PowerPoint using the Start menu then, when you get to the shortcut, right-click it instead of the usual left-click. If you choose properties, won't it show you where the exe is?
Oooh! Nearly got me going with that right-click and properties move!
But when I follow that thread it takes me C;\users\neil\appData\Roaming\microsoft to a pip file.
If i look at the Properties/details it says the file name is Microsoft Powerpoint2010.lnk
I'm still none the wiser . . .
Cheers,
Neil.
Is there a way (that I have forgotten maybe) whereby "system files" and the like are hidden from the normal 'view file' screens? Maybe my beloved ppt.exe file has just been masked from me . . . ?
Hi Neil,
Going on that path do you log in to a domain when you start the PC and does Roaming profile mean anything to you ?
Alistair.
Hi Alistair
Yes, it's a multi-domain home computer. And the "roaming" doesn't mean anything to me. I tend to leave these sort of things alone, and only work on the raw program and data files.
Makes my wife say "why don't we get a Mac?"
The link file contains the reference to the application - you need to get to the folder containing the lnk file and edit / look at the properties to see the path to your powerpoint file.
Alistair.
Hi Alistair
A mac isn't any better or worse - just that folks tend to tinker less because they don't understand how to do any damage on a mac.
Fire up the shell and I'll show you how to damage a mac ;)
A.
Hi Alistair
Anyway, proper reply. Do you know how to search your whole computer and all drives for an application named powerpnt.exe ?
Alistair.
Hi Alistair
So are your shortcuts to Powerpoint (the .lnk files) in
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office
if so - in "set file associations" - navigate to that folder then double-click on the Powerpoint .lnk file
The link in C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Microsoft Office file point towards c:\program files (x86)\common files\microsoft shared\virtualization loader. I chose the CVH file, which when I go through the "set default" process, allows me to choose Microsft Office Client Virtualisation Handler to open the Powerpoint file.
Still no sign of "powerpoint.exe"!
Neil.
