. Mmmmmmm so if there is no torque for these screws they cannot be over tightened?? (if you follow me).
So if they crack it can't be my fault, and should be replaced under the gaurantee.![]()
If they crack it actually will be your fault because you overtightened them.
If you`re incapable of judging how tight to make a fastener in this sort of application then you shouldn`t be doing the job and may be better advised to go back to playing with your Lego bricks.
And you claim to be a Project Engineer,too.
What the feck is it with so many of the 1200 lot ???![]()
You sound like one of those helpful chaps who
"knows all & knows Fcuk all"
I don't suppose you know what a torque wrench is, let alone a torque setting.
Wind your neck in and play with your Russian tricycle until you can afford a descent (2 wheeled) bike.
Thanks.
My kit of parts has steel bushes not plastic as discribed. Everbody says "do not over tighten", in engineering this normally means "use the torque setting"??. Mmmmmmm so if there is no torque for these screws they cannot be over tightened?? (if you follow me).
The BMW Winglets came with the parts in my drawing. The drawing shows the assembly recommended by the CW guy. I have looked at the components and the only way is the CW way. Unless we have missed something. Your suggested assembly method seems to ignore my BMW kit of parts?There should be 2 plastic washers, to sandwich the winglet.... just nip the nut so its tight , use nyloc nuts so they won't come undone... if you haven't got any plastic washers I'd source some![]()
4 Captive nuts, 4 Top hat section stainless steel spacer, 4 plastic washers, 4 Torex set screws, 2 Winglets.
did'nt yours come with the same bits as mine?
Cheers, at least I don't have to change them.Your diagram is exactly how I fitted mine...right or not they have been fine for 2 years. It seems to be consistent with:
http://www.realoem.com/bmw/showparts.do?model=0380&mospid=51731&btnr=46_1033&hg=46&fg=55
I'm not sure about torque settings...I just did it by feel. No cracking and they haven't flown off...perhaps this make me eligible to join the elite group of 11xx riders?
Thanks, but this does not agree with http://www.realoem.com/bmw/showparts.do?model=0380&mospid=51731&btnr=46_1033&hg=46&fg=55Nothing goes under the body work, its all on the top.
These are on a 2010 gsa,
Don't think it matters if the bush goes in from the top with the washer on the bottom or the other way round with the bush in from the bottom and the plastic washer on the top.
your looking at the older 2008 setup,
parts on the 2010 model look like this,
21 Fillister head screw M5X20SI 4 06 32 7 657 966
22 Flat washer 4 46 61 2 308 594
23 Flange sleeve, steel 4 46 63 7 724 481
24 Grommet 2 46 63 7 709 435
grommets per winglet.
I'm not trying to be thick or prolong this thread but....my kit of parts are the same as the one you listed (only 2 rubber grommets). CW Dorchester tell me that the rubber Grommets are not usedTwogrommets per winglet.
One in each hole.![]()
. Also they advised me to install the Winglets as per my drawing at the top of the thread.
