I am just about to add some spot lights, (already purchased), to my 2001 R1150GS
I want the near side to be on with low beam, and both the near side and off side to be on with high beam, so do not want to use the switch that came with the lights.
As the bike is already set up this way for it's headlights, am I right in assuming that I can take feeds from the wires going from the handlebar switch to the headlamps and take that to the specific relay for each spot lamp?
I've searched the internet, but can't find anything useful.
I am going to make a loom up so I can put the two relays in the current fuse box under the seat, with a positive feed direct from the battery.
Or is there a better way?
