wiring in a hein gericke led brake light
  • Thread starter Thread starter silky
silky
Hi all
I need your help.
I have just bought a hein gericke led brake light I am having no joy making the thing work, I have tied every which way to connect to the existing wiring any help and advice greatly appreciated.
My bike is an r1200gsa anniversary 2010
got a feelin your Canbus system is gonna spit it out....."Nien, dont like that shite". The led's will be drawing less current so the Canbus will think the bulbs gone.
That's the way I understand the canbus works, may be wrong.
Ride safe
Gary
Is this a seperate and additional jobbie from the existing rear-stop/tail light or a LED replacement for the normal bulb?
The issue may be the can bus as suggested but it does depend exactly what you've got.
The computer expects to measure the amount of current associated with a normally functioning tungsten filament in both the stop and tail lamp.
If it measures too much it thinks it's a short and will cut off that circuit for safety. If it measures too little it thinks the filament has blown but its gets quite smart as if the tail lamp has gone, it switches the brake light on but at half power in order to look like a tail light so that people can see you and not run up yer chuff in the dark.
Now then, LEDS don't use nearly a smuch power as a filament so will look to the computer as a blown bulb. All replacement LED's for canbus bikes need an additional resitor in parallel with the LEDs in order to provide enough load to fool the computer into thinking it's seeing a working bulb.
If you have bought a replacement type you need to check this aspect.
If you have bought a secondary lamp, you may be overloading the circuit and causing it to shut down. Tell us what you've got and we'll go from there
er,teapig you do know that a 2010 gs has led rear lamps and not tunsten filament?
Fitted the exact same LED unit to my topbox , connected via a 3-pole w/proof plug Just tied it in to the wiring to the tail / stop light, i.e. paralleled off the wiring at the back of the rear light unit. My bike is the 2010 GS. Works o.k.
Problem solved Cannons BMW Braintree gave me a wiring diagram and sent me on my way. fantastic dealer.
It was simple in the end the problem was me not the led light!
Many thanks to all who took the time and trouble to reply much appreciated
Safe riding
