Deleted account 181015003
- Joined
- Jun 16, 2012
- Messages
- 13,017
- Reaction score
- 5
My bike since new F800GS 2014 has always has a wobble sort of oscillation on the handlebars on a closed throttle it has been back to the dealers a couple of times to fix the problem and to some degree a new front wheel improved it.
The problem seemed to happen when the bike was doing about 50 mph and if I closed the throttle I could feel a side to side wobble through the bars if I released by grip it could be clearly seen getting worse as the bike slowed down and would settle at about 25mph.
I always suspected the OEM Pirelli Scorpion tyres but there was no way to prove this without changing them and I was not going to replace 2 good tyres just to find out. After 4400 miles the Pirellis were past their best and I have a trip coming up in a few weeks I thought now is the time to try something else I bought a set of Anakee 3s from Tyreleader and fitted them last night this afternoon I tested then no more wobbles so if anyone has the same symptoms and Pirelli Scorpions tires the tyres will be more than likely the cause.
The Anakee 3s seem to ride really well and the bike tracks and corners great I was going very steady just to scrub them in and worryingly I am at the edge of the tyres all ready the profile does not look to allow very much lean angle and I am a bit worried I will run off the edge the front looks the worst when comparing it to the Pirelli that I removed
Is anyone using these tyres on a F800GS and has any issues riding off the edge of the tyres I am no cornering god so dont expect to be on the edge just running them in ?
) said if it works for you why change? So I didn't. Would others be better or worse? I'll never know.
