dancata
Although symptoms are not obviously hall sensor related, gonna have to part with some reddies at Motoworks. Stripped out fuel pump again and checked and thoroughly cleaned tank, pressure excellent with a strong flow of fuel to the injectors. Problem has got worse with same symptoms, just more exagerated. Bad to start, dies when throttle opened, misfires and stalls. Gonna try the hall sensor route. Apart from wiring harness or motronics can't think of enything else to try... Will be back!!!!
did you mess with the metal round thingy that runs between the HES? if that 17 screw is not tighten correctly, all the simptoms you described above occur.
