paulh
Hi, This may seem simple but...
I bought an '09 X which seemed to have excessive play at the twistgrip, that is the adjuster couldn't remove all the play!. I've checked the twist grip internals, not much to go wrong here (?), bought a new cable from BMW and it's exactly the same as that fitted to the bike...?
Checked 3 different fiche systems and MaxBMW seemed to have the answer as it showed photos of the cable ends against a rule for... the CLUTCH! However the Xchallenge/moto versions also showed photos of the throttle cable and since the throttle body 'ends' are all the same I assume the inner cable should 'stick out' 8cms as in the photo (I'm assuming of course that the inner is pulled out completly?), mine (both new and old) stick out 9.5cms?
If you have an Xcountry and would like to help please advise 'stick out' length, position of cable in twistgrip housing and adjuster position (the last two by no. of threads showing) so I have a definitive answer before I start looking at other items on the bike.
If you have an Xch/moto, though the o/all cable is longer, the 'stick out' length should be the same (?), so please advise dimensions as above...
If you're reading this bit you're either extremely bored or want to be helpful, I hope it's the latter!
Thanks in anticipation...
P.S. Any X owners near me...PE6?
