You all told me.....
24 miler this morning clumber park and sherwood forest best invention ever 😊
Some times a good off road route will resort in the use of footpaths. No problem with a mountain bike but an electric bike weighs a ton and wouldn't be too easy to lift over stiles. And I know that I shouldn't be riding on footpaths but needs must
Tut tut :P
Some times a good off road route will resort in the use of footpaths. No problem with a mountain bike but an electric bike weighs a ton and wouldn't be too easy to lift over stiles. And I know that I shouldn't be riding on footpaths but needs must.
Some of the best off road rides are singletrack through woods and across craggy mountain sides. I can't imagine they would be much fun on a hefty electric bike.
I think it will be a long time before I trade my carbon Zesty for an electric bike.
When you are allowed to travel, come and have a go on mine - You’ll change your mind
I was told by my local bike shop NOT to use the Co2 cartridges if you’ve gone tubeless.
Was that just before they sold you an expensive pump :D
I also use Co2 to Seat a new tyre
You don't "need" to go tubeless at all.
It's not a bad idea but definitely not a "need"
I’ve had a ride with three punctures, proper squirters. When hear the sealant squirting out, you brake hard and quickly get the hole to the bottom and it seals.
With a 29 2.6 tyre they hold a lot of air so normally if you’re quick you can carry on without having to put more air in. As mentioned already, quite often you only know you’ve had a puncture when you see the tell tale sign of sprayed sealant
My view on tubeless is why not - if the wheels are tubeless ready it’s a simple to do
I’m now off mountain bikes for the next 4-6 weeks - I’ve just had the MRI results from my fall 'fractured collar bone'
That’s was from falling of my single speed MTB
Said he, regarding lifting a bike over a style, or onto the roof of a car.
None of these challenges with a Brompton.
Now just try riding it down a bumpy trail.
If the inherent instabily doesn't get you, the small wheels and ruts will.
Theres no resistance on the new Bosch motor in his bike.
Tell me about this.
I have a roadgoing ebike and a trail one.
The roadgoing ebike has a Bosch motor, and small driving sprocket. Therefore, there is gearing between the pedals and the sprocket. This equals losses/resistance.
The trail bike has a Bafang motor with a normal sized front sprocket and a freewheel between it and motor, so no resistance. Having said that, the bike is heavy, so, with 1/3 of my heart muscle goen awol, non ebikes are out for hills.
Tell me about this.
It mentions it in the video in this link. https://www.emtbforums.com/2020-bosch-update-new-motors-625wh-battery-and-more/
Who said they were fine in the wet...
This is an esteemed member of this very fine parish no less.
There’s no accounting for the lack of talent!
I'm thinking that daft fucker has just freewheeled down a hill after stopping for a chat! not realizing he's forgot to switch the fucker on! as soon as he's tried to pedal..... "Bang" down he's went, measuring about 4.2 on the Richter scale ;) causing a Giant Tsunami in Tayside
Nah bollocks, I've seen his work before, if fact I have a rather large dossier on him.
I made the mistake of letting Mrs Nutty have a go on the ebike last night. She came back grinning from ear to ear, and now wants one of her own. :blast
Tell me about this.
The pre 2020 Bosch Performance Line CX Motor has a small sprocket and a 2.5:1 gearbox. I run a 20 tooth sprocket which equates to a virtual 50 tooth. The problem with these motors is that the gearbox has drag and past 16mph equates to "hitting a brick wall". The 2020 CX motor does away with the gearbox and does not have the associated drag.
I actually like the drag on the previous motor as beyond 16mph, the thing is very hard to pedal (basically a 26Kg bike with the brakes stuck on). So you get a genuine workout but the bike helps you up hills.
I changed mine from standard to 18 tooth (I think?) which kind of gives me an extra gear or two at the top end which is better for high speed, but I kind of loose a gear at the lower end when cycling up steep hills.
De-restricting is your answer.
Road bike: (Bosch) on Sinus BC90. Fully automatic gearbox. No desire to de-restrict. Full power up to 25kph, then a gradual reduction to no assist at 27kph. Beautiful assist characteristics.
Trail bike: (Bafang G510) on a Frey AM1000. The 1000 stands for 1000w/1000ah battery. I have often had it at 80kph. Lost my nerve there. It is limited to 90kph. De-restriction is by USB link to computer. Have never felt the need to go any faster on it.
I did, however, reduce the assist in power modes 1 & 2.(Out of 10). The bike was just to difficult to ride on twisty trails. Never use it on trails beyond power mode 2. Just unrideable.
When I originally decided I wanted an eBike Mrs B was very sarcastic and said it’d never get used, more money than sense, she wouldn’t want one and the rest of the usual bollocks then she came with me when I went to buy one, had a test ride on one and we came home with two.
