Zumo 660 - new map 2013.1
NLC
North London
Folks save yourself hours of headaches. After trying to fit an elephant into a bedsit I gave up, conceded defeat and called Garmin tech support.
The new map 2013.1 just released for all of Europe will not fit on the internal memory of your Garmin. The Western Europe map option #2 will fit on your Garmin. To update goto the Garmin website (mygarmin) log in with you account and select map update. For the Mac, Garmin Lifetime Mapupdater is crap. If you need more maps than the unit can hold then buy a SD card and use Mapinstaller to upload additional maps onto the device. Downloading the entire map to your computer will save you the headache of logging on to the website.
Good luck and good night.:beerjug:
Oddly, I updated mine, and it did just that, by magic:-
/Volumes/GARMIN/Garmin/gmapprom.img 2.09GB << Western Europe
/Volumes/GARMIN/Garmin/gmap3d.img 500.3MB
/Volumes/GARMIN/Garmin/gmapbmap.img 51MB
600MB Free.
And in
/Users/ian/Library/Application Support/Garmin/Maps/City Navigator Europe NT 2013.10.gmap 3.27GB
So if I need the database of Lithuanian Pizza I can just squirt them onto the SD card:-
/Volumes/EXTERNAL/Garmin/gmapsupp.img Currently, Open Source Florida.
7.8GB Free.
So in a post 2 minutes ago, I raised an eyebrow at their testing and what it copies back on connection to Basecamp, but the auto updater seems to have a bit of a clue.
:thumb Garmin.
It'd be good if they detected it and asked if you wanted the whole lot moving to the SD card (perhaps leaving the 3D in internal storage), but with all the shonky ebay cards about, it'd give them a support headache.
600MB Free.
And in
7.8GB Free.
:thumb Garmin.
It's not pretty but it works. I've already got Western Europe on the main card. In any case if you have the main map loaded on the computer you can push parts of Europe you need relatively quickly to the SD card.
600MB Free.
And in
7.8GB Free.
:thumb Garmin.
did you need to delete any files on the unit manually, or did the update process handle it all?
I deleted all the voice files I didn't need from my Zumo550 a while ago.
I couldn't get ALL of Europe (which I wasn't happy about) on my unit at the last update (before this) so settled for western europe only.
Now I find that even that won't fit on the unit and I don't really want to use a card as I like using that for music.
I am not happy with Garmin and won't ever buy another unit from them, what is the use of a hard drive so small it won't accept reasonable updates???.......or am I missing something?
Must be doing something wrong there mate. I got western Europe on mine without a problem. Try deleting the old maps and doing a reinstall.
Nope, I deleted the supp img file last time, so only had lifetime file and base one before updating.
New to Garmin, my unit is showing as having an old version of the mapping software. I have downloaded the latest map through the updater but it is prompting not enough space to install.
This is on a brand new unit,
How do i delete the old maps from the unit and replace with the latest update.
I've learnt to ignore the updates for Garmin.
If the unit as it stands links with your computer and you can programme in routes and waypoints, STOP at that point! Do not pass GO, do not collect £200. Be happy and leave the thing alone! The less a GPS has contact with the internet the better as far as I am concerned.
You may miss out on the odd new Spanish road (we stopped building new roads in UK years ago) but the thing will work!
glad you asked that before I did as I have the same problem.
Are you running a Zumo 550 or 660, the 550 doesn't have sufficient space for the current version of Western Europe. The 660 lacks enough room for the whole of Europe.
If you have a 660 then you need to install Western Europe via the on-line updater. Doing this from Mapsource or MapInstall will introduce a few issues: It won't install the Junction View and 3D buildings files. Additionally it will create a supplementary mapping file rather than a primary mapping file, the former will be written alongside the latter and there will be precious little space available.
The on-line installer will overwrite the existing primary mapping file and install the Junction View and 3D buildings file.
If you're used to working with older Garmin models such as SP2610 then you may naturally assume that installing mapping from Mapsource is the correct approach. This is not correct for updating the primary mapping, you need to use the on-line updater.
As above, if installing to a 660, use the on-line updater and select Western Europe as the region to install as well as installing full Europe to your PC. You can then use Mapsource or MapInstall to write any other areas of Europe you require to either the remaining space along side the primary mapping, if your needs are modest, (I tend to leave 100MB free) and/or the SD card if you need more data than will fit into the remaining internal memory.
If you are installing to a 550 then you are now in a position where it's best to install to PC only and then use Mapsource or MapInstall (the latter usefully reports free space and how much will remain) to write a supplementary mapping file to the internal memory with the mapping tiles you need and will fit. Once you have done this you can rename the mapping file from GMAPSUPP.IMG (primary mapping file) to GMAPPROM.IMG (supplementary mapping file). This isn't absolutely necessary but will prevent accidental overwriting.
The issue of the Junction View and 3D buildings file are not relevant on the 550 as it doesn't make use of them.
Sorry to be a numpty or sound like one,
It is a 660, It was bought brand new this week and is the very first sat nav i have owned ever,
I have base camp on pc and from there on in i am completely clueless.
OK, so the updater is prompting you saying that there's not enough space to install the mapping update. What it's saying is that there's not enough space to install all of the update. By following though the process it will offer you a list of regions, for UK residents the best option is usually Western Europe, this will fit with space to spare. You also want to select the option to install the mapping to both your GPS and your PC. The latter will receive the full update. The whole process will take an hour or three depending on your broadband connection.
The web updater will install the new mapping overwriting the old, out of date, mapping.
There are full instructions here.
Thanks for that i will try this at home tonight,
I tend to set it up and once it states that it's started and will take x hours I go and watch TV, sleep etc.
What I meant by that was this will happen on your GPS, both old and new mapping will be on your PC. The old mapping can be removed from there by the usual methods.
I wonder how long it'll be before we're downloading all the maps to the GPS using the 2610 way :rolleyes:
And another thing, why can't I select more than one region to down load at any one time? I'm off to Croatia in September so have to download the Western Europe block to the GPS and Croatia and Slovenia to the PC (by downloading the whole lot) and then transfer it to the 660. Pity I'm not going down through Italy and across on the boat to Greece :rolleyes: :rolleyes:
Most 'older' users of Garmin use Mapsource which is an option you might consider. Mapsource uses individual files in much the same way you might expect with a word processing package.
BaseCamp on the other hand is more like iTunes with a monolithic library of all the waypoints, routes and tracks you ever reference. You then set up 'playlists' to cut down this monolithic collection and view just the bits you are interested in.
I am trying to be positive about moving to BaseCamp but for most people Mapsource might be an easier learning curve, plus there are excellent tutorials on this site.
Thanks for the help everyone, with the help here and a little bit of reading i now have the update installed and working just fine :)
