zumo music
Not open for further replies.
cherokee
shoeburyness
ok guys need some info,loaded music onto the 550 zumo,which is hardwired to the Katoom,iv got UE in ear monitors which im going to use to listen to the satnav instructions and music,i prefere these rather than bluetoothing the audio.Can any of you guys tell me if i can get a extention that i can plug into the zumo jack,and lay in my tankbag so i can plug my ear monitors into,and where i can get it from...MTIA.....:Motomartin
If you are just going into the Zumo jack it's a standard 3.5mm stereo jack plug.
You can certainly get an extension from Maplin's. They only cost a couple of quid. You may even be able to get one from somewhere like ASDA, or somewhere else that sells headphones.
You need a 3.5mm Jack to 3.5mm socket stereo extension.
Edit. http://maplin.co.uk/Module.aspx?ModuleNo=11425 - £6.99 which is certainly higher than you can pick them up from elsewhere.
