ZUMO won't power up
  • Thread starter Thread starter Deleted Member I
Deleted Member I
Am I doing something wrong or is the unit dead :nenau
Started it up first time last night. Registered and updated the unit.
It still all worked when I finish updating. Powered it off.
Today it won't power up?
Is there any technique or things to check?
Battery dead. Lasts 4 hours when not working. You left it on didn't you? :P
Novice.
Try holding down the + and - keys together with the power key.
This will re boot the satnav. Should come on from then.
If not then power it to the mains and try again.
Friend of mine sent his zumo back when all it was was this:blast
