LED Tail Light
Received the LED tail light from Bulldust today, & have now fitted it.
The reason that I bought it was that the GS tail light is a single bulb, & it is often killed off by vibration. There is nothing to alert you to this, unless you physically check. In fact when I went to do a comparison photo, the bulb was burned out. The bulb holder was originally chromed to give a better reflection, but this has come off in places. The tail light is also not very bright.
The replacement unit replaces the bulb holder & the bulb, & sits in the stock tail light. It is very tidy. The metal stays push over the tail light plastic screw holders, so it is positively held in place, somewhat proud of the taillight base unit. There are white LEDs on the back of the unit, pointing downward, that comprise the registration plate light.
Installation is pretty much plug & play, except that the wiring is different to the colours of the standard GS loom. Not really an issue. Brown is ground, the black LED wring goes onto a dual coloured wire with black in it, which leaves one other wire to connect. I re-did the 90 degree connectors on the GS loom, basically so that I could cover them (they are bare copper, & given the wiring is not captive anymore on the plastic bulb holder, I didn’t want them shorting out anything if they moved.
With the tail light / reflector screwed back in place, the light is way brighter than the stock unit. The brake light increases the intensity of all of the red LEDs. From the rear of the tail light, you can just make out the individual LEDs.
I am very pleased.
