Twin spark misfiring
Glad you found it, and hopefully before you'd gone too far down the expensive "Change it all bit by bit" route :D
It would have been a major pisser if you'd finally found it was that 4p's worth of hose after changing everything else :D
Least said I reckon Bill, at least now it should be good for several hundred or even thousand miles! Fingers crossed.
I seem to recall that U shaped hose being stupidly expensive when I refurbed the innards of my tank...
I had some spare hose kicking about in the garage Matt, just lengthened it a tad to minimise the kink.
If you haven't already, make sure it's hose that's designed to be immersed in fuel - it's available at your motor factors, but is a different spec to normal fuel hose...
Mike :cool:
Eggzakkerly what I did when I was on my quest to try and solve a very similar problem.
Be careful though- I found that the petrol-submersible grade longer pipe I installed ballooned out like something you see in a heart bypass procedure........It didn't split, but it caused confusing and very hard to trace erratic problems of its own.
Mike's right, it obviously does have to be petrol-submersible, but it also has to be rated for higher pressure than normal carb pipe.
It is available though, by the meter (or units smaller than) at a LOT less than the OEM pipe, but there's a fair chance that the 'spare bit of pipe you had kicking around the garage' won't be up to spec for both pressure AND submersability (oooooh I think I just invented a new word! :D)
It is proper fuel line but whether it's capable of complete immersion is another thing. I guess I'll find out!
Mine did the same thing. Very hard to see but very obvious once dissected. I had a total power loss. I bet there are many Oilhead in-tank hoses ready to fail.
Don't disconnect the return QD while the fuel pump is running! It's a great way to blow off or blow open a line in the tank. The pressure can easily reach 2X.
Worked fine for me with a bit of common sense applied.
I'd replace it now hops - why spoil the ship for a ha'porth of tar? :D
If you want the correct preformed U-piece, prepare yourself for a shock... :eek
Most decent motor factors will be able to get the correct submersible fuel injection rated hose if you don't fancy shelling out for the ridiculously expensive preformed OEM part.
After what I've spent so far another £20 or so for proper hose seems in order even if it does grate a little for such a small piece of pipe.
