The Moose
I have a 2010 GSA with Metzeler Tourance Next tyres on. What should I be running the pressures at?
I'd go for the higher option of 2.4/2.7 or 2.5/2.8 if you often have a pillion/luggage. You'll notice low tyre pressures more 2-up than you will high pressures 1-up IMO. I'm not Valentino Rossi though!
I need one setting for either solo or two up as often switch between the two.
Have been running them a lot lower as that was the pressures fitted. 2.1f/2.2r showing on the dash.
Will pump up. Probably 2.4f/2.7r or similar.
Just stick with what the handbook says, repeated on the bike with a sticker.
That would be 36 42 then. The bike manual has always been low to what Metzeler recommends.Personally, I'd go with what the relevant tyre manufacturer recommends. It's their product, so they should know. The handbook is correct (possibly) the day it is printed. Tyre technology changes.
