After check absolutely everything o the bike still have the problem..remove the tank checked all the engine bay for strange things remove all the connectors from ecu zfe and double checked everything..put all according manual all the sensors all the connectors..still the knock sensor 1after 4100 rpm read stranges values due to knock sensor 2..
knock 1around 90volt
Knock 2 around 50 volt
The bike now run extremely smooth..every move at the throttle and it revs so easy..work perfectly..but due to the values of knock sensors..im afraid only for a few days as always..
Now i will check mechanical things
Like valve clearance again
Camshaft worn
Timing chain for any noise..
Hope find it..
Στάλθηκε από το JSN-L21 μου χρησιμοποιώντας Tapatalk
Camshaft worn
Hope find it..
