thick spacer is front left Pete
Thanks Gordon! Hope all’s well with you and the family?
catch up some time in 2021 when life is back to normal and both our 100's are back on the road
Looking good...
Now, can someone recommend a source for Molykote or similar for the gearbox input splines?
Optimal TA - great stuff . . . . There's a 1/2 kilo tin of it here . .
Bring a small tin or jar .
Bob.
Top tip: before clamping down the top yoke, check that the electronic rev counter cable (if fitted) is on the correct side of the fork stanchion! Doh!
pop the binnacle off the top mounts and reroute the cable the way you want
Not when it’s behind the stanchion but needs to be in front, Jay. The pic is the “after” pic once I’d dropped the stanchion an inch or so
Cough Cough Unplug it inside
Fair enough. I have to admit, I could not be arsed wading through the wiring in there behind the speedo etc and went for the reverse of what I'd just done. If it's a simple male/female plug, that would have been easier right enough.
Talking of plugs, I looked at the wiring from the handlebars and discovered the front brake light switch had parted with one its feeds. Bugger! Another call to Motorworks.
The switch is fecked Jay with wire pulled out and green mush inside the plastic housing. Way beyond soldering. Main oil seal looks ok with only clutch debris around the bell housing. Oil pump, I’ll leave alone: if it ain’t broke ...
You have owned a landrover before haven;t you"If it ain't broke!"
Yeugh Yes that does somewhat put a Kibosh on the soldering
All I was saying was "While you are there" because remember you have to take all of that stuff off again to get back in there
Or would the Local Lingo be "Afore Yee go!"
Oh and So you can enjoy the lovely wiring of your Airhead GS
This is a twin shock headlamp shell ( I hate going in there in case something that is weak cracks or breaks)
