Purplegerbil
I have a 2003 r1150gs and have changed the exhaust to y piece and black widow can. It was running just fine but would occasionally cut out at junctions, lights etc. Always re-started no problem. It didn't do this before I changed the exhaust. I couldn't get the old lambda sensor out of the original exhaust so used a spare one, I figured this could be part of the problem so swapped in a new one. It now backfires through both exhaust and airbox whilst sitting on the bench. I haven't ridden it.
Whilst plugging the new sensor in one of the quick release fuel pipe connectors got damaged so I have now changed both of these to the metal type.
I haven't been able to balance the throttles yet because of the poor running. All pies etc under the tank do not look to be kinked and both throttle cables are correctly seated.
Any ideas on where I should start, I don't get much time off so don't want to be retracing every step if there's something simple I'm missing.
Thank you in advance.
