Wingit
OK, I know this has been done to death over the years so apologies for sending anyone to sleep...However:
My standard GS screen is doing my head in. The settings are: Mind numbing turbulence position through to wind noise increase position. Somewhere inbetween I've found a compromise that is not perfect but OK on short trips but a nightmare on long motorway journeys.
After a fair bit of research on the forums and even more umming and arring I bought a GIVI screen. This has proved to be worse at certain speeds than the original BMW screen.
Has anyone out there found a proper solution for a 5 foot-10er to sit on the GS at 80mph-ish in smooth quiet airflow???
I understand the Tobinators work very well on the 1150? And are an 'improvement' on the 1200? Anyone got any comments or advice on Tobinators for the 1200???
I would even consider the obscenely expensive Desierto III fairing/screen if it solved the problem. Has anyone used one of these? Can anyone give me any feedback?
Any advice would be greatly appreciated.
Cheers, Ken
Cheers, Ken
I can happily do the ton plus (on a closed road, officer) with this set-up and have so far not felt the need to look for an alternative screen.
) with the visor fully open.
