GS800NR9
moderator said:There seems to be two problems associated with stalling on the F650/800GS.
1. The bikes are fairly high-geared and the engine lacks the flywheel or reciprocating mass momentum of the boxer twins, so when asked to pull from very low revs it sometimes just gives up. Sometimes the engine cuts out when waiting at lights in gear with the clutch in.
2. In order to meet Euro emission regulations, the fueling is quite lean at times and under certain circumstances can cut out. The answer to this might be for the dealer to load a revised fuel mapping.
Extracted from thread on user reviews...
The motor quit once on me today. I felt a hesitation, grabbed the clutch and checked the instruments. Speedo was showing 50mph and the tacho was on 0 rpm. Hit the start button and carry on. Luckily i was pretty upright when it happened and not overtaking. It was pretty wet, but nowhere near as bad as yesterday. Hasn't happened since so im not sure what caused it.
I read your last write up with interest. I had my 800 cut out as well today,going around a corner, had to put my foot down and then hit the starter. Scared me a bit, I was travelling at 10/15 mph not the speed you would expect the motor to cut out at. Needs checking out. ( I thought it was me having a crap rider moment, now I am not so sure)
On the plus side I love the machine, engine, exhaust, handling, looks, price. Need some handguards though, I think the seat is okay but not done more than 70 miles in a oner, got an Airhawk just in case.
Paddy
Hmmm, think this cutting out thing needs keeping an eye on Paddy. Maybe BMW can check for a fault code but i'm not going to make the 70mile trip to the dealer unless or until it happens again.
Be interesting to see if any more riders have the problem.
After much trawling through threads on the F800.org site here is what i can gather is one possibility on the engine cut out.
If you ride for a certain distance or time ( 50 miles is a figure mentioned which roughly ties in with my experience )without stopping or returning the throttle to fully closed then the ECU recalculates the fully closed position of the throttle, presumably based on the furthest point you moved it back during a gear change or slow down at junction etc.
Then, during a gear change or some other occasion of low throttle, in my case i believe i was going from 4th to 5th, if you close the throttle beyond that new zero point then you are in a negative throttle value and fuel is shut off to the engine. Engine stalls.
I would have put this down as a one off on my bike if it wasn't for Paddy having an engine cut out too and the approx 10 pages of stuff on the other forum about it.
It may sound a bit like goofy software but it does tie in with the characteristics of my ride yesterday where i never came to a complete stop at any lights for the previous 48 miles (another significant figure may be i had just passed the hour mark).
There is talk of software updates etc so i'll be talking to the dealer next week.
