Larry Langford
Aslo a little more on air breathers, especially the high flow gauze and oil types like KN need to be cleaned at least once a year, especially if your riding around diesel vehicles a lot. I have found that the K'n will look perfectly clean on visual inspection, but is in fact completely full of minute diesel particles. I have these in my trucks and have committed this error several times self, even to the point of getting codes from the PLC.So, you may have other issues, other than the fuel map. could be a dirty air breather ... and gobs of other things are possible.
It is hard to tell from here, I don't know how steep that hill is. But I wouldn't go back to the leaner map if I were you. The clutch is prolly not the problem. You may have simply found the limits of the 1150 in power .... The 1250/1300 would accelerate into triple digits miles in a couple of seconds in that same scenario, very likely. Any time you go for an older bike your going to have a project on your hands. You watch them closely and try to correct things before they become a breakdown out on the road. If you say, want to learn mechanics, then your right where you need to be. But if you want a turnkey bike and are going to have other people fixing the bike, then a lot newer bike might be in order, just saying, not being critical ....
Do clean those breathers a least once a year or more. And of course, follow the cleaning directions to the tee with the K'n, no exceptions .....
