Like most bike horns, the 800's is too wimpy for my taste. Has anyone fitted a more powerful one I wonder? If so where did you put it?
you have mail
via your user name![]()
, when i strapped a claxton to the side of my bike in an attempt to evade psychotic Indian Truckers.......
you basically have the other end of a canbus. You add some clips to the ends of the wires which then connect to the horn.....So once I had pinched the connectors onto the ends of the bare wires with my Leatherman I connected the + and - wires to one end of the horn and the other female canbus connector to the male connector on the bike and bingo it worked a treat. .....
My F800GS Stebel Air horn arrived from Nippy Normans today. I'm still at work so wanted to fit it at lunchtime. I realised that I didn't have the correct sized socket to take of the existing bolt of the old horn but thought as I'm impatient I will at least wire it up for a test run.
The wiring is very straightforward and doesn't require instructions. you basically have the other end of a canbus. You add some clips to the ends of the wires which then connect to the horn. Be sure to put the plastic sleeves on before you attach the metal connectors. It will become self evident when you come to do it yourselves.
So once I had pinched the connectors onto the ends of the bare wires with my Leatherman I connected the + and - wires to one end of the horn and the other female canbus connector to the male connector on the bike and bingo it worked a treat. When I get home I will take the hold horn off and replace with the new one which fit's into the space for the old horn.
Hope this helps
Jon![]()
