Sharpey
Right then. I have a brake problem, which I think is a variation on the usual story. The warning triangle is coming on mid-ride, with the brake failure warning flashing merrily away.
Cut and paste from an old post by 'Wapping' is that the very likely causes are:
(1) That the front brake lever is getting slightly caught behind the hand guard. Check that the lever can 'flick forward'. If it can't simply tilt the hand guard so that the lever can.
(2) That the rear brake switch is engaged. Adjust the rear brake pedal if it is.
Check both the above quite quickly by looking at the rear light, to see if the brake light is on.
(3) Last possibility is that the speed sensor for the ABS (behind the rear wheel) is playing up, or possibly (less common) the sensor in the front wheel. If your speedo is behaving normally, this is probably unlikely.
Due to the joy of being made redundant at Easter
, I now have the time to go through all this, check the exact failure warnings, check the owner’s manual etc. etc. (I was hoping to just ride the thing as a way of forgetting the lack of work...!)
To be honest, I am not mechanically competent, don't have the tools or facilities. Yes, okay, I admit it, I am a numptie. Please be gentle with the abuse... But I've made a start in correcting that - e.g. recently did some basic wiring in of some accessories. With a strong desire to keep my money away from BMW at the moment, now would seem to be a good time to make a start on figuring out which way around a spanner goes.
I'll post back up here to let you know how it goes. If nothing works, I'd like to hear if there are any other ideas, and perhaps get some help from any mechanical geniuses in the Brum area.
David
David
I know, a fairly low threshold, but I am beginning to think that I don't want to be learning bike repair sat on my driveway fiddling with the brake system...
