Had a bit of fun today trying to sort out my final drive output bearing. I didn't get any notice of impending doom then felt a bit of a rumble. When I took the rear wheel off the oil seal had been displaced.
Removal of the seal revealed the cause. The bearing had disintegrated
Had a bit of a problem getting the old bearing off as my pullers would not fit under the bearing as it was too close to the crown gear. So, the old remedy, large hammer and chisel to lift it slightly then wedge a chisel either side and lever against them.
Off it came, quite easily in the end. So bits in the freezer and others in the oven, hopefully a happy ending is nigh. Follow steppers advise and check yours soon!
The old and the new:-
