Touratech Spotlights - Wiring diagram
m0ng00se
Kent
Hi Guys,
I have recently purchased a set of Touratech spotlights on eBay, however, I think the previous owner just cut the cables when he removed it from his bike.
Obviously the instructions doesn't really help with just wires everywhere.
Is there anyone who have done an installation of these spotlights who can give me a simple wiring diagram. I have a centech A1 box, so planning on running it to there and not directly to the battery.
Currently I have:
2 x spotlights each with a red and blue wire (flat connectors) Both also have a brown wire coming from the blue wire that seems to be cut.
1 x switch with a cut yellow wire (assume this goes to the yellow low beam wire)? and 2 blue wires (also flat connectors on them)
1 x fuse holder, but I don't think I will be using this as I will run it to the Centech unit.
Then, I have 2 relays (stuck together with double sided tape). One is a no-name brand and the other a Hella one. I assume the Hella one doesn't work and the previous owner replaced it by sticking another one onto it.
If anyone has a simple wiring diagram, it would be appreciated.
Thanks Tim, that link helps a lot ... will only install it after coming back from my trip in South Africa in 2 weeks ... my bike will be sleeping at the dealership for 2 weeks first to sort out an engine problem it has !
Terry, thanks, but I already have that. I assume from reading that, they have some of the stuff already wired where my wires are just all cut, so wasn't sure about the wiring to the relay, etc ... but the link Tim gave will certainly help.
If you have some time, it would be greatly appreciated if you can have a look on your bike so I can just confirm all my stuff will be wired correctly :thumb
Thanks again ...
