Decided to fit a pair of Bullet LED's at the rear. I took some time deciding where to fix them and ended up making a pair of brackets. If I was making them again I'd change the design a little (always the way). Anyway, they do the job.
I also fitted the gismo which enables them to be used as brake, as well as rear, lights. Here's a picture of the lights on, but not the brake.
In this location on the rack they are reasonably out of the way, clear the panniers and top box, but clear enough to give a bit more "width".
Easy enough to wire in direct to the rear light wires. Just a PITA getting the rear cover back on and keeping those pannier frame spacers in place.
