Ok Tossers, I need a bit of help. Done the search thing and none the wiser except 1 reply which said the symptoms disappeared after while.
The bike suffers from clutch slip when accelerating hard in 4th gear and only in 4th gear. Noticed it when overtaking 2 trucks on the A507. Checked it later on in the ride and the revs just rise to between 6000 to 7000 rpm with the speed creeping up steadily while the revs stays steady until it's time to change gear. A bit like the Audi Multitronic if you know what I mean. Came back, parked the bike and not ridden since. Logic says that if there is an oil leak the clutch would slip in every gear. Bike just had engine, gearbox, final drive oil change. If it would help the bike is a 1200GSA, 09 reg and 12700mls on the clock. FBMWSH. Out of warranty off course. Don't want to split the bike before I know what to look for or alternative fix.
The bike is reliable and not a lot of problems, but not as reliable as my R1100S with no problems except tire wear
