R1100GS Potentiometer Setting
beaky bike
Wellington, New Zealand
Recently balanced and synch'd carbs on my 1996 1100GS and seems to be running pretty well but wanted to check my CO level as my plugs are a bit sooty. My bike has no CAT and no O2 sensor in the exhaust so I am assuming I adjust my CO % using the potentiometer under the seat? Got is checked today and it was reading just over 8% !! Before I go racing in and adjust this can anyone tell me which direction (when on your back on the floor looking up at the adjecter screw) I turn this screw to reduce to CO value to close to the 1.5% +/- 0.5% specified.
Clockwise weakens it, it is slow to respond and an endless potentiometer, so it goes right back to the top if you go too far :thumb
I measured the resistance across pins 1 and 2 earlier and it seems that the POT is 0 - 1k ohm across about 14 turns. I will take it fully clockwise (weak) ad start there. Thanks for the help.
