Humbug
I bought one of these heated jacket kits a while ago but never got round to fitting it. http://www.heat4jackets.com/
As it was getting bloody cold the other night and I had to make an early start to Dorchester and then Poole I got my nearest and dearest to finally sew it it for me.
Duly hooked up I tried it on the bike statically - it seemed to get warm but not that warm.
Set off the next morning, over the top out of Crewekerne the temperature was reading -5C!!! Jacket didn't feel much warmer than usual and I was glad of the heated grips.
I thought the Canbus may be tripping the auxilliary socket but when I got to CW's they loaned me a R850R and I plugged it into that for the trip to Poole. This made me realise that the GS screen does give surprisingly good protection as on the naked demo bike I was f*ckin' freezing!
I got back home and checked all the connections - they seemed okay but to be on the safe side I soldered them all. Tried it again but it was no better. I hooked a 12v charger to it and wrapped some of the heating element around a temperature probe and got a maximum reading of 37C - which is not that warm - certainly not the very hot the instructions tell you the wire will get! I could put it in my mouth with no risk of burning!
The length of wire has been checked and this is the recommended 33 ft.
I removed the long, thicker guage attachment cable and attached the 12v source direct to the heating element/wire. It ran no hotter. I placed a voltage meter across the power source, unconnected to the heating element and got a reading of about 13.5v with no load but with the element connected, the voltage drops to around 9v with a load of just under 4 amps.
I have emailed to seller and he has not come across this before and has been very helpful so far and has even offered me a full refund including postage costs. I don't really want that as I want the heater kit to work!
Could there be a problem with the element wire causing this voltage drop? I am no expert of electronics so any advice would be much appreciated.
Andy
Andy
