can't resist telling the truth in front of inaccurate eulogies
climbing96 said:
Ladies and gentlemen. I may have come across a fix for my 2009 GSA. My right hand has been going numb, and I would need to use my left hand on the throttle to give my right hand a break.
botus said:
2010 TC, above 4k rpm I get a numb right hand within a few mins.... ride for 20 miles >4500 rpm and you need a day to recover from a "white finger" type episode..."
I for one agree entirely with comments about unreasonable bar vibration from the 1200 TC engine... and indeed I've also found a wild impossible change when playing... Please note I still have my hex head and I've done 30k miles on it, and even done 1000 miles in a day - with no real issues (if you remember to take your airhawk cushion !) - but now I've bought a TC as well, this new thing has really horrible bar vibration as it goes above 4k rpm and, I get a numb right hand. The bike is like brand new and its only done 9400k miles - and I agree below 3k RPM its miles more refined than the old tractor, but everywhere else, performance and NVH is a car crash from hell
Looking at causes and solutions (or not) I just found a thread on advrider.com hoping to see if anyone makes anti-vibration mounts - So far things are not going well at resolving using basic servicing ideas... First I checked and tweaked up to FT the engine mounts, then did the valve clearances, oil change to a posh brand of semi syn 10w50 to MA2 spec. pushed 300ml of atomised water / meth 50 50 mix through the throttle bodies revving around 3 to 4k to clear out any gunk on the inlet valve side of things, and in doing that found the floor of the air box full of a greasy oil solution which I cleaned out, re calibration of the idle stepper motors, then re-balanced the throttle bodies. All of which has made zero difference at all to how it runs or vibrates...
Then two week back on a Friday a strange occurrence brings an interesting perspective on the rest of climbing96's post (in advrider.com) - it clearly shows he doesn't understand how its engine management set up operates (what he has written later can't have any effect)... but
then something odd just happened to me that makes ZERO sense on my bike either...
I just had the bike's I-Level flashed for the first ever time (last week by a main dealer). Some 12 years ago somehow it had never got the UK std. point of new sale software update that dealers are meant to perform... but now they claimed nothing got updated... and it WAS indeed going just as badly when they gave it back. And whilst I have given it about 100 miles over 4 rides to see if its adaptions settle to something better (after the I-level update) - I was getting no improvements....
indeed this thing (as it has in the 500 miles I've had it) still struggles to rev out past 7k rpm regardless of 99 unleaded or not. Until I fitted one more anti-vibration attempt THAT CAN'T POSSIBLY cause the engine performance to change, but APPEARS to have had a dramatic effect on the bike during my last ride !!!
Still attempting to make the bike rideable above 4k rpm, I bought the handlebar bar brace from BM germany - the one fitted on the original 2006 Adventures (see options on OEM parts listing for 2008 and 2010 GS's), I put that on then took it up the road.... what appears to have changed, is now the left bar vibrates a lot more than I remember, and the right maybe subtlety less but both are still buzzy and nasty compared to the head bike.
So I start some diagnosis - going along holding each end of the bar brace between my left fingertips - the left vibrates at a very different frequency to the right side which has a much higher frequency buzz.... overall all I recollect now is the left bar vibrate much worse than it was - the right is still terrible, but intriguingly my right hand didn't actually go numb this ride ????.... then I went a bit harder on a highway and wasn't really impressed with the change - I was really just riding to get some miles on to allow the oil to warm up so i could give it some exercise - then when I ripped it (I'd forgotten to put in S mode and the traction hit in hard). Of course not for the first time - but its first time I forgot since the I-level update... And suddenly this seems to have woken the DME from a 12 year slumber - Ever since its pulling through passed 7k rpm with a vigour its not had previously - and I'm even getting some air under full throttle in 2nd as it revs out - (something it never managed previously)
All rather odd and confusing - either it got an engine ECU update but its been ignoring change till friday's heavy traction control intervention made it re think life -
(sounds a bit far fetched even for BM's incompetent workshop procedures) or (and even more irrational), the bar brace has reduced bike vibrations till the engine knock sensors are happier ???
