GS Ted
Ok thanks Greggers, that makes sense
As some of you may know, I'm on a bit of a jaunt at the moment (see the link at the bottom) and have just arrived in Moscow on the trans-siberian as my clutch went when I was 70 miles out of Irkutsk on the way to Moscow. I had a new one shipped from Hursts Motorrad in NI 5 days ago and it still hasn't arrived at the address I've arranged for it to be posted to (Parcelforce world priority is allegedly 2 days, but Russian customs are not a fun place for parts). Anyway, I've heard that the clutch on an 800 is easy to get at...does this mean that it's easy to replace too? I'm not the most mechanically orientated, but I've got a tool kit with me which should cope with it. If anyone cares to give me a blow by blow account on what to do at the station once the clutch arrives, I'd be grateful. Or do I pay the horrendous Moscow prices for a mechanic?
Thanks in anticipation,
S
Ta,... thought i'd keep you posted.
cheers,
s
i stripped everything down and found that the main nut behind the clutch plates had come off
Try the adjuster down on the LHS of the engine block, by the actuating lever.
IIRC there was an issue with BMW not leaving enough slack there. In any event it's worth a try, just be sure to have at least 5mm slack lever travel when you're done...
) and mine's right in the middle, roughly the same number of threads showing top and bottom. The bike's done 15k, 13 of which are mine. I'm not gentle with it and have ridden it how it was designed to be - the adjustment's never changed!
