Firstly the following is: IMHO based on 45000+ miles on TKC80's over the last four years, fitted to an R1200GS, F650gs Dakar, two F650gs's '01 & 04' and an R100GS Paralever. I personally get very good mileage from these tyres, with as much as 14000 from a front and 11000 from a rear, fitted to my 1200GS. This mileage is based on approximately 98% road 2% gentle off road.
If you have read any of the promotion material for TKC80's you'll know that along with the Metzler Karoo, they are very highly rated in the overland world as a first rate all rounder. Unfortunately it's never made quite clear that the TKC80 is not a road specific tyre and shouldn't be associated with being so.
This 'I think' is why the 'new to the off road tyre' users can become disillusioned or confused with the handling characteristics of this type of tyre. After all it ain't no road tyre.
TKC80's are designed for prolonged use on a large capacity, fully loaded (often with passenger) heavy motorcycle, primarily on the un-made roads of Eastern Europe, South America and Africa, whilst maintaining acceptable handling characteristics when used on metaled road surfaces.
As with any off road tyre, the pressures recommended are considerably lower than those of conventional road tyres. I run all our bikes with 27psi in the front and 32psi in the back. When touring with luggage or carrying a passenger I up both ends by 5psi. Higher pressures will give the tyre a much less confident feel and because they are a bias-belted (one step up from a cross-ply) tyre rather than a radial they are more likely to react to impurities in the road surface, like grooves and bumps etc. (I noticed when riding on cobbled passes in the Alps, they gave the impression of being flat). There is a plus side to the bias-belted tyres in that you can feel them starting to 'walk' before they completely lose grip. This is especially noticeable with the big knobbles on the TKC80's and of course it's very handy to know when you've reached the limit.
The TKC80 has an aggressive knobbly tread pattern. This equates to a road/tyre contact point of roughly one third of a normal road based tyre. Therefore trying to run the same pressure of said road tyre, is going to give the impression of riding on marbles. Which I'm sure you'll agree in some what unnerving. For instance; The R1200GS has very light steering with a new road based tyre like a Tourence or Anakee. This is quite normal and a trait of this specific bike. It's also one of the common reasons why hardened 11** riders don't tend to like the 1200 much. With a new set of TKC80's fitted it can beccome quite scary, especialy for the first time user.
Because of this difference in road contact, the steering can be as much as 50% lighter than it was with your last tyre set-up. This is not a particularly nice feeling, especially with a new TKC80 up front. Also the new to TKC80 rider will very likely find that they no longer trust the front end of what was previously a great bike.
So bearing in mind that these are not road tyres, it stands to reason that they shouldn't be treated as such when riding. They will be a bit skittish, certainly when new, and do need bedding in before they 'and you' settle down to the different way they respond to rider input.
A wise man once said to me: You have to let yourself trust them.
He was right. You do need to allow yourself time to become accustomed to TKC80's it's very important that you give your bike it's head. A bit like riding a horse fast. If you hold on too tight the horse will be come confused and you'll both end up getting hurt. Give it it's head 'a light hold on the bars' and it will do what it needs to with out drama.
As for the issue of speed; The TKC80 is rated to 99mph. I have personally taken the 1200 to over 120mph with little more than a light feeling to the bars (on a straight road mind), I have had the 650 gs's and the Dakar 'with it's 21" wheel' up to their limits including casing down much more powerful bikes through the twisties. The older 100GS Paralever is not the best handling bike around and needs to be treated with more respect than any modern bike. However I have not noticed anything odd when changing from conventional tyres to TKC80's. All this is with no more than a light feeling up front.
However if you hold the bars too tight you will experience much more of the weave so commonly associated with these tyres. Having said that. TKC80's are an off road based tyre with a limitation on speed. very short bursts of speed don't do any harm. But prolonged high speeds over the recommended limit is not a good idea, for obvious reasons.
With a bit of relaxed confidence and a bit of time to get used to them, you'll find that your still able to do pretty much the same things as you could on you road tyres. I still touch my boots down on tight bends and roundabouts, I still ride the same in the rain as I did before. Other than the obvious respect needed I don't find TKC80's (with the exception of the top speed rating) to be any different to road tyres.
Ride safe and have fun.
Val.
