1100 Caliper bolts - need torque setting
Kenny
Trustworthy Scouser AND
Moderator
Moderator
Toxteth scouser, made good ..now hiding on Wirral
Got some nice shiny new caliper bolts ( the 4 each side to hold the actual caliper halves together )... can't find the actual torque setting for these bolts, so before I set my left arm to 'feckin' tight' torque, has anyone got the torque settings for these bolts, please?
I just did one at a time ..... 'fairly tight and a little bit more but not too much'
hope that helps:thumb
Now if that had been me it would have been, just tight enough and then half a turn too far doh!!!
Well you are about 15ft tall ( and wide :P) ...I'm quite an :angel compared to you :D
Test driven and all OK:bounce1
Fitting Goodridge hoses this week ( well not the rear as the F***in stupid supplier off Ebay has forgotten the rear hose :mad: )... so all should be stoppidy doo :)
