Gearshift lever torque setting
Mad Hatter
Ain, 01, France
Can anyone please tell me the torque setting for the bolt that attaches the shift lever to the gearbox (the one that passes through the centre of the shift shaft). I can’t find a figure anywhere in the repair manual.
Personally I find that tightening until you need to apply ANY force to the tool to turn the bolt in Then at that stage its 1/8th to 1/4 of a turn and not any further :aidan
It's usually Damn close and NOT a danger in alloy :rob
Transmission shifter lever:
The 13 foot-pounds specification has caused confusion. The bolt that goes through the shift lever into the transmission has a diameter of 6 mm type and is 80 mm long, and it requires a 5 mm allen wrench and 6.8 Nm. I torque that bolt to 5 foot-pounds, which is the same as 60 inch-pounds.
Section 21 -23
https://bmwmotorcycletech.info/torquevalues.htm
Section 21 -23
Superstar. Many thanks Dr F:beerjug:
