1100 HEAD LIGHT ADJUSTMENT?
Smartbazza
Moira, Norn Iron
back on this one again,
wat did anyone who has adjusted the height of the light use on the adjuster? bit small for a spanner.
and what direction will bring it up?
tia
I use a spanner, just get a small one that fits.
Lengthening the adjustment rod, points the light down, shortening, points it up!
Mick.
the ball joint on the threaded rod pulls off (carefull) the headlamp shell which makes access/adjustment easier, then push the ball joint back together
Jeff
