ahebron
Finally fitted the 1100 FD to my 1150GS. So far so good but one problem I had when fitting was the distance from the lh pivot bearing to the front of the fd was longer on the 1100 than the 1150 one. I had to file a 8mm radius on the edge as the fd could not be bolted in due to the pivot holes not lining up because the fd was fouling on the lh inside of the swing arm. The 1100 fd was dated 12/94 and the 1150 one was a 2002 model. My bike is a 2000.
Anyone else had this issue?
Adrian
Adrian
