1100GS removing front indicators
essjay
Drogheda, Ireland
Trying to figure out the best way to remove the front indicators on the 1100GS as I want to mount a set of GMT moto brackets.
It definately seems a bigger job than doing it on my old 1150. Had a look through the Haynes manual but I can't see it covered anywhere.
So what do I do?
So what do I do?
Unscrew the lense, then the 2 screws holding the arm, then the wires then pull it out.
no - i have to take the whole stem off. seems to be a few threads on it but it's still a bit vague to me
Its a while since I did it but I removed the headlamp shell to reveal the nuts holding the flashers on. I think :rob
Stewart
headlight off, remove cover the underneath , then undo the nut that holds the stem on .
sounds easy doesn't it.. actually its a royal pain in the neck... but once you've got the headlamp off and can see what you're doing it becomes easier.
