Richard J
Any advice would be good chaps.
2003 1150 @40000 miles
The clutch lever needs to be pulled almost right back to the bars to disengage drive. Gear changes are getting more clunky (so its probably not disengaging fully) and there is a squeaking sound (in neutral or gear)when the clutch is released(goes as soon as the lever is pulled back slightly)
The clutch is not slipping
Is it big strip time or just a hydraulic problem (fluid level seems OK and no obvious signs of a leak)?
