Right, an update.
Did as Neil suggested, I even swapped the injectors from side to side.
Yesterday I fitted a section of clear hose in the fuel lines using spare QD connectors to physically watch the fuel being pumped through!
I got home all depressed and rang in to work to arrange to borrow the Spec-lift truck, admitting defeat and prepared to take the bike to Ocean.
Now the spooky bit.
I woke-up this morning at 4.00 having been dreaming about the throttle-cable run and specifically the cable on the offside.
I dreamt that I found that the cable wasn't seated properly just like Neil and others had suggested.
It was the first thing that I checked when the problem occurred (after replacing the fuel-line clips) and I have checked and rechecked both sides. God alone knows how many times I have checked that they were seated in the bodies correctly.
This morning I resisted the urge to go straight over to where the bike is and jumped on my 75, nipped in to work and drove away in the Spec-lift.
Before getting the bike out I thought I'd have another look at the cables.
The nearside one was okay and sat fully in the body.
So was the offside one.
For some reason I peered at the end that disappears into the splitter-box under the battery tray. It looked fine.
Then I looked again and saw what I can only describe as a dark and thin crescent beside the black cable sheath where it goes into the splitter-box.
Getting some long pliers I pushed the cable over and about an inch of the sleeve shot into the splitter-box!
Even without trying the starter I knew that was the problem solved.
Sure enough, it fired-up and ran on both cylinders!
I hadn't at any stage considered that the cable sleeve had or even could have pulled out from the splitter.
What an absolute pillock!
I took the Spec back, big daft grin on my face and decided that I'm so happy to have the thing running again that I'd accept the piss-taking here and give everyone the opportunity to say "told you so."
I spent a happy few hours adjusting the valves, the TB's and generally just fettling things.
Right, I've braced myself for the comments, so let's get it over!
Oh. Just one thing, I will be putting a note book and pen beside my bed for the next few nights, just in case I dream of the winning Lottery numbers!
