1150 gs (03) speedo cable replacement - help
ronnie69
Newcastle under Lyme, Staffs
Not usually a technical chap , but thought "how hard can it be?" thanks to handy dandy posts on here - new cable is connected to back of speedo at the top, but before I put all the dash and screen gubbins back together again, I thought I'd just check the cable first........ However, on turning the inner cabley thingy at the bottom of the newly-connected-at-the-top cable, I expected to see the speedo needle do something, but it isn't moving at all.
It was definitely a faulty speedo cable that caused the speedo to fail in the first place - the inner bit had broken at the bottom end, because it fell out when my mate took the bottom of the cable out to check it.
From the posts on here, it seems it would be a REMARKABLE coincidence if the speedo cable driver doofery thingywotsit on the wheel had failed at EXACTLY the same time as the cable broke - or am I wrong ? I suspect I'm doing something daft or overlooking something obvious. :blast:blast
Any suggestions, wiser ones? Bike in drive half finished now , so look forward to suggestions asap, please.
thanks in advance, :beerjug::beerjug:
If you're just twisting this round by hand you won't notice any movement on the dial simply because you won't be able to turn it quickly enough.
If you want to test it stick a drill on it or just connect it all back up and spin the front wheel.
tosser to the rescue again
cheers, popeye - not had chance to check your suggestion, cos it went dark and there's no light in me shed, so it'll have to wait til tomorrow, but sounds like what I was after. Discovered I need new main beam bulb which I can't get til tomorrow, so does no harm for beastie to be in bits for another day. Ta v mucherly. :guitarist:beerjug::bounce1
