1150 GS Engine Colour
B4ndit
Hampshire
I am planning to touch my tired looking old engine.
I know guys on here have painted there engines with Hammerite silver smooth and got good results.
I have just had a look at Halfords on line and Hammerite do a 'Silver' and 'Grey Silver'.
From those that have done it which one gives the best results?
http://www.halfords.com/webapp/wcs/..._productId_180243_langId_-1_categoryId_165495
http://www.halfords.com/webapp/wcs/..._productId_157655_langId_-1_categoryId_165495
Looking at the pictures I am guessing the 'Silver' one is best but I would like other peoples feedback on the products they have used.
Hammerite Smooth 'Silver' for me:
<a href="https://picasaweb.google.com/lh/photo/y4-tn4wX9n85O9pH2cyhhsdIjVbFe8lpPsa0N09Tvn4?feat=embedwebsite"><img src="https://lh3.googleusercontent.com/-flLNHDKZRlc/TFGhh8eGNbI/AAAAAAAADfg/HaxWq2K1GVA/s800/IMG_5581.JPG" height="800" width="600" /></a>
<a href="https://picasaweb.google.com/lh/photo/hbrgsqboHln1wP5PgfCaOBJAieIP4IByCYmMpeOVcwI?feat=embedwebsite"><img src="https://lh6.googleusercontent.com/-aNhhS_X-r-Q/TG_4IdIdJJI/AAAAAAAADps/KqVSuGQNdK4/s800/IMG_5641.JPG" height="600" width="800" /></a>
<a href="https://picasaweb.google.com/lh/photo/l8p_sBe8GWjmiTO5s7EqRxJAieIP4IByCYmMpeOVcwI?feat=embedwebsite"><img src="https://lh4.googleusercontent.com/-jfXdaSPK7Xg/TG_4J33Bo7I/AAAAAAAADpw/R8oBVARzlFA/s800/IMG_5642.JPG" height="600" width="800" /></a>
Mattw,
When you painted the rocker covers did you remove the original paint first or simply rub down & spray over the top?
Mine are getting a bit tatty and I`d like to tart them up a bit.
Cheers,
Mattw,
Cheers,
Mine were badly bubbled on the front faces of the covers and in between the fins on the front. I removed all the bubbled paint mechanically and feathered the edges of the remaining sound coating. I used a home made 'tool' in a dremmel (a disc of scotchbrite green pad). Before painting I degreased them thoroughly (in the dishwasher - don't tell the missus ;) ) and then went over the whole cover with a fine (grey) scotchbrite to key the old coating and gave it a final wipe down with panel wipe.
<a href="https://picasaweb.google.com/lh/photo/tqeSBpz2ksMabZmquzPE3xJAieIP4IByCYmMpeOVcwI?feat=embedwebsite"><img src="https://lh5.googleusercontent.com/-HEdHcq470ns/TG_4HcH44hI/AAAAAAAADpo/EAsrGyxAvsI/s800/IMG_5634.JPG" height="600" width="800" /></a>
<a href="https://picasaweb.google.com/lh/photo/ATpB4VsUwzLIdLBwoblURhJAieIP4IByCYmMpeOVcwI?feat=embedwebsite"><img src="https://lh4.googleusercontent.com/-aWi8-lDcfPQ/TG_4jA_I3YI/AAAAAAAADqA/r79-vBYhfbU/s800/IMG_5635.JPG" height="600" width="800" /></a>
cheers
Matt
Thanks Mattw, Thats exactly what I needed to know. That the Hammerite can be applied over the existing paint without any chemical reaction.
I too have some Scotchbrite "tools"
Looks like the old bus will be treated to a coat or 2 of Hammerite silver over the winter. :thumb
Thanks Again. :)
Thanks Again. :)
No worries - glad to be of some help.
Enjoy the fettling :thumb
I wondered if it would need some etching primer on the exposed bits?
Tibs
You have a good point about primers.
However, everything I read on here (mainly MikeP's write-up's) before I did my front cover and then rocker covers, said that Hammerite on the bare alloy was ok.
It's proved to be the case - the front cover and rocker covers have both done a couple of years and still look good. All the paint is still well stuck and the finish has stood up well :thumb2
