Mongolian Explorer Registered user Joined Mar 5, 2014 Messages 288 Reaction score 1 Location Somerset Jul 5, 2016 #1 What colour does what ??
hops Well-known member UKGSer Subscriber Joined May 21, 2003 Messages 3,235 Reaction score 154 Location Wirral Jul 5, 2016 #2 Don't suppose this helps?
Mongolian Explorer Registered user Joined Mar 5, 2014 Messages 288 Reaction score 1 Location Somerset Jul 5, 2016 #3 hops said: Don't suppose this helps? Click to expand... Can I conclude red is the power feed ?
Nin Well-known member UKGSer Subscriber Joined Feb 23, 2006 Messages 5,400 Reaction score 597 Location Abingdon, Oxfordshire Jul 5, 2016 #4 Can you narrow it down a bit? Sent from my iPhone using Tapatalk
Mongolian Explorer Registered user Joined Mar 5, 2014 Messages 288 Reaction score 1 Location Somerset Jul 6, 2016 #5 Nin said: Can you narrow it down a bit? Sent from my iPhone using Tapatalk Click to expand... Red being power feed to switch, what do the other 4 wires connect to ?
Ian J Hartley Well-known member UKGSer Subscriber Joined Jun 15, 2003 Messages 5,117 Reaction score 473 Location Swindon, England Jul 6, 2016 #6 Mongolian Explorer said: Red being power feed to switch, what do the other 4 wires connect to ? Click to expand... Why don't you lift the tank and follow the wires from the Ignition switch loom to the connector located at the headstock (orange connector). You can then see which wire goes where with relation to the wiring diagram. Simple really.
nud1e Registered user Joined Aug 12, 2003 Messages 1,868 Reaction score 1 Location Crumlin, Co Antrim, Northern Ireland Jul 6, 2016 #7 red - + battery violet - not used green - F1 fuse box, engine stop switch, ignition coil, abs warning relay, horn relay, load relief relay, alternator grey/black stripe - light switch, warning lights panel grey - F2 fuse box
Mongolian Explorer Registered user Joined Mar 5, 2014 Messages 288 Reaction score 1 Location Somerset Jul 7, 2016 #8 nud1e said: red - + battery violet - not used green - F1 fuse box, engine stop switch, ignition coil, abs warning relay, horn relay, load relief relay, alternator grey/black stripe - light switch, warning lights panel grey - F2 fuse box Click to expand... Thank you
