On my way up to the NEC Show on Saturday I had a problem with my 03 1150 GSA ('03, ABS, 57k) – cruising along at 70mph on the M40, I'd done about 60 miles from home when there was a sudden loss of power and the bike slowed.
I throttled on a bit and it made a terrible racket, sounding and feeling like it was running on one cylinder.
I pulled straight over and had a quick poke around but nothing was obvious. The bike stalled as I stopped and was hard to start again. I didn't want to hang about on the Hard Shoulder so limped a mile to Oxford Services where I had a proper look.
Again nothing was obviously amiss. Throttle cables were properly seated, the coil packs were replaced a couple of years back and look in good shape, plenty of fuel (around half a tank), fuel pump sounds like its priming on key turn and the pump itself was replaced less than 18 months and about 12 to 15k ago. No blown fuses, no snagged fuel line, tried the Motronic reset as a last-ditch attempt but made no difference. Since pulling in to the services I've not been able to start the bike. Plenty of juice in the battery, she's turning over ok but not even coming close to firing up.
Called the AA and I was (eventually) relayed home.
The Hall Sensor has been suggested as a possible culprit but I'm not 100% sure what that even does let alone where it is or how to test it – and I'm assuming the "test" will be to buy a new one, fit it and see if the bike starts!
A quick Google has thrown up other possibilities of water in the fuel, a blocked fuel filter, or a split fuel line inside the tank.
Any other pearls of wisdom? I could really do with getting the old girl running again asap!
) then the above will not produce that symptom.
