1150GSA Clutch Replacement
mad-dawg
Harrogate
Hi
Searched the threads but no conclusive answer so advice please. Clymer manual says white marks on housing cover and pressure plate must be 180° apart.
Tsiklonaut mentions 120° apart on his post (http://www.ukgser.com/forums/showthread.php?t=153714&page=1) between two parts above and white mark on face of flywheel, Clymer makes no mention of mark on face of flywheel.
So the question is;
Is it 180°
or
120°
Hi
So the question is;
Is it 180°
or
120°
120° - from the BMW Service Manual:
120 + 120 + 120 = 360! In practice though if they are a bit off it doesn't really matter. Just use new bolts... probably more important than spacing on clutch plates.
Got new bolts, along with new everything else, don't want to do this again in a hurry.
For anyone interested, braided clutch hose from Sherlocks is about half price of Motorworks item.
Clutch plate was almost down to rivets so new kit going on.
How many miles on the bike ? Is it the bikes first new clutch ?
Just curious how long they last ish
Bikes done 60k guess its the first clutch but only had it for 3k miles.
It's getting changed while gearbox is being rebuilt
When its back together everything engine backwards will be as new.
:D At risk of sounding like 'mines bigger than yours' syndrome here, and starting a 5 page fukkin dick comparison, my 1150 is starting to slip under hard acceleration (4k rpm upwards) in 4th gear through to top and she's on 85K miles - uses no oil between services either.
Winter project me thinks.:rob
So your only changing it because your in the gearbox then ? Guess it wasn't slipping so it would perhaps have gone on to higher miles. Somewhere between 70 and 90 k miles then perhaps if the clutch isn't abused.
Eh not a bad return that is it. :thumb2
Don't know why but I had about 50k miles in my head for a new clutch :blast
Suppose riding style is a big factor. I don't have any so it will probably be 30k miles for me. :blast
Yes it wasn't slipping but it's daft not to change it while box is out.
Glad I did, looks like there is only 1 mm left before rivets are touching.
I guess previous owners either did drag racing or loads of slow speed CBT stuff :)
....and you'd be right, going that far in and you'd be an utter plonker and a silly fucker not to change the clutch.:D
Unlike me when I had me gearbox overhauled by Steve in Sleaford last winter, as I was skint, I didn't do it:blast:blast:blast
:D
2003 GS-A
171K-KM (not miles) and stil the same clutch,and gearbox..
It's a clutch. Wear rate all depends on the rider and where it's ridden.
Used in london don't be surprised to get about 20K miles, even less. My loan bike needed one at 18K miles.
That explains why it's Fekked!
Bike spent most of its life darn sarf :D
It really doesn't matter.
I've noticed when replacing customers clutches that the ones fitted when assembled at the factory are usually never at 120 degrees. They are all over the place.
