Shep
Shep of the Dessert
i have the preload on the back on minimum, and the damping half a turn harder than stock but it needs a tad more. front is on min preload too. works ok 1 up.
not done much 2 up yet but feel the rear shock will be totally out of it's depth then. hope i'm wrong, wilbers are not cheap![]()
Why have the rear set so low? it drags its arse like a dog with worms on the lowest settings, but perhaps your one of those slim underdeveloped types that could do with a good meal in them![]()
Fronts OK on minimum, but you can check that with a cable tie lightly fixed around one fork leg, if the tie(after good ride about is right at the top of the forks stroke, add a bit more preload until it feels right, generally a waste of time though as the minimum setting is usually best at the front![]()
Shep
Gone and done it....deposit down on a new 1200GSA in silver (oi none of the bo****ocks about aluminium white or one colour being faster than the other - decision made
), probably end of March delivery (snap! Mike Murphy
(last time I spoke to her I was looking at a used 2002 1150GSA....what's a couple of grands between loved ones eh
on the go at the moment but need to choose one over the other, so is it 'dependable but dumpy' Miss 1150 or 'unpredictable but slim' Miss 1200.....somethings gotta give
, aka possible life saver) may go against the reason as to why I (I, I may add) enjoy biking.
