1150r Instrument cluster question
adventuredon
Wandsworth, London
My clock, speedo and rev counter are slightly loose in the cubby holes. How do I tighten them, or are they meant to a be wiggly? I tried tightening the speedo by the torx on the rear but that's not solved anything. Anyone had similar? Its like a loose tooth. Wiggly but there..
Cheers, Its not affecting operation, but from the diagram it seems likely to be either the perished grommets and a damper ring. Its def tight and not falling out. Its looser at the front and if I shoved a toothpick in from the front it's probably sort this, so that's my guess. Thanks
