12 G/S satnav set up advice
Jeremy
Devon
Looking to fit a satnav, probably a Zumo, to my G/S. Can anyone share pictures of their set ups?
Jeremy
I have a samsung galaxy tab 3 active mounted on the oem nav bracket. it runs the bmw app and uses the wonder wheel. I also have DMD2 installed and control that with a bluetooth remotek one.
Thanks for that. Does the unit sit above the standard G/S screen? I'm using my iPhone/Waze on a powered/dampened SP Connect bracket attached to the handlebars but I feel it's been shaken to bits.
Yes it fits nicely above, as would a phone. If I knew how to share a pic I would. I’ll try tomorrow
has anyone fitted a satnav to the handlebars?
I’ve only picked my bike up. It has the BMW connected thingy so I’m using my iPhone and the Motorrad app. I’d also like to use my nav 5 at times . Is there a dedicated power take off for the BMW mount or will I have to use the din plug ? ( I have a BMW mount already adapted).
Could you share a picture of the BMW mount? Vertu Exeter are asking £800(!!!) for the nav prep on my GS so I think I will pass.
I can, but it’s not the mount that’s expensive it’s the wonder wheel etc. The mount itself just clamps to the bars and is like a quad lock mount.
what device / bracket do you use to hold the tab 3 for mounting onto the nav bracket as their quite big
